https://sierramadreresearch.zendesk.com/hc/en-us/articles/360004015872-Is-my-gear-compatible-with-your-gear-
In most cases our gear will work with what you already have. If not directly, we have tips to help make sure the fit is secure.
We designed our hammocks (the Pares specifically) to be most compatible with our shelters, but as long as your hammock is a packable gathered-end camping hammock, you should have no trouble using it with our Stratos or Nubé Hammock Shelters.
A bridge hammock will also work in our Stratos Hammock Shelter with only minor adjustments to the suspension. On a few of the Bridge Hammocks  the suspension tie outs at each end are wider than necessary, to fit into the Stratos Fly you’ll need to slightly decrease that width and by draw the suspension ends  together, giving you a better fit inside of the Closure Sleeves.
If you have more questions about how your gear will work with ours, please contact our customer service team, and they would be glad to help!
Email: Customerservice@sierramadreresearch.com
Call or Text: 908.444.6767
