All the new emails will be automatically routed to the New Tickets bucket. If you're given permission to assign tickets then please go ahead and do so. If not proceed to the next step. You'll have your own bucket of tickets under your name. That's ...
The Hot Pocket doesn't charge; it only heats. We'd recommend charging the Power Pack instead for first use. If using a standard USB charger, it's best to give it 24hrs of charge. Note that as long as you have 2 bars of power, you can use your Power ...
If you're trying to figure out how fast you can charge your Power Pack, here's how it works. Take the total number of panels you have, multiply them by 7. Now divide that number into your Power Pack's capacity, the Power Pack UL (40.7Wh) or Power ...
If you're trying to figure out how fast you can charge your Power Pack, here's how it works. Take the total number of panels you have, multiply them by 7. Now divide that number into your Power Pack's capacity, The Power Pack UL (40.7 Wh) or Power ...
