https://sierramadreresearch.zendesk.com/hc/en-us/articles/4404749808027-Product-Information-Inferno-MKII-System
Inferno MKII System
A pro-level system designed to provide complete and unparallel fit, coverage, and warmth.
Features
1. Full coverage Spacious top quilt design gives you space where you need it and complete warmth
2. Flex Fit under quilt ensures the best fit no matter how diagonal you are. (Snug Strips help keep your warmth in with a tight seal)
3. Fabric differential helps eliminate insulation compression
4. Heat Strips overstuffed insulation - where you need it most.
Product Specifications
- Works with any of our hammocks or other gathered end hammocks
- Under Quilt was re-designed to work with Ninox SL and DL's aggressive diagonal lay
- Variants: Top Quilt, Under Quilt, 30°F, and 0°F (temperatures)
- Materials: Exterior Fabric: 20D HydraSHIELD (weather resistant)
- Interior Fabric: 20D AIIR (breathable and soft hand touch)
- Insulation: 800FP Waterproof DownTek Down (RDS)
- Suggested Max User Height: 6ft 6in
- Top Quilt Dimensions: Length 83in Max Width 29in
- Under Quilt Dimensions: Length 88in Max Width 51in
- Top Quilt Packed Dimensions: 30°F 13in x 7in | 0°F 15in x 8in
- Under Quilt Packed Dimensions: 30°F 13in x 7in | 0°F 15in x 9in
- Top Quilt Weights: 30°F (1lb 5.1oz (598g)) | 0°F (1lb 8.3oz (763g))
- Under Quilt Weights: 30°F (1lb 4.4oz (578g)) | 0°F (1lb 12.5oz (808g))
- Top Quilt Insulation Fill Weight: 30°F (11.7oz (315g)) | 0°F (18.2oz (515g))
- Under Quilt Insulation Fill Weight: 30°F (11.11oz (331g)) | 0°F (18.9oz (535g))
- Included: Top Quilt, Stuff Sack, Cotton Storage Sack AND / OR Under Quilt, Stuff Sack, Attachment Suspension, Cotton Storage Sack
Comparisons/Differentiation/Scope Docs
https://docs.google.com/document/d/1Th3zvmnCc_QBJKVaIYhKsroLyMgUbeq4Q0N5CzPrZOs/edit
Internal Video
https://drive.google.com/file/d/1tuqficFOOsJQAdpNZsuP5_Hd8I6zSck1/view?usp=sharing
Design Video
